the weather is finally cooling off down south . on my last ride i noticed a little off idle hesitation so i decided to go up one size on the pilot jet. . bike was set at 155main,42 pilot with the needle clip in the top position with the air screw turned 1/2 turn out .we ride mostly around sealevel elevation. i recalibrated to 155 main ,45 pilot and moved the clip to the second from the top postion and the air screw 1 turn out. it idled super high and barely responded to adjustments in the idle screw and idled down some if i closed the air screw all the way. i even returned the settings to where i started and the S.O.B. still idles high and still wont respond to adjustmests in the idle screw.and again it will only idle down some if a close the air screw all the way. wtf is going on here???? :bang: :(
