iamdawalru5
- Apr 26, 2006
- 82
- 1
I picked up an 82 yz125. I put gaskets, reeds, orings piston and ring into it. ****ed with the little poor excuse of a carburetor so it wouldnt leak out of every overflow (couldnt get float level near to what it needs to be) and finally got it started. It ran well surprisingly. I warmed it up, pulled the clutch in put it in 1st and it felt like that barely warmed up "slip", the revs go down a little, it takes off a bit and then stops and revs back up. I let the clutch out slowly and nothing happened :coocoo: I looked down at the motor and gas was pouring (this isnt the surprising part) and oil was running out of the end of the transmission at the sprocket which just had a seal installed recently :think: If i remember correctly I had the clutch in again and it felt like it went into neutral. So I tried the process again, clutch in, down to first and it stalled. hasnt started since, fresh gas, getting gas, getting spark What the heck????
