john_bilbrey
- Mar 22, 2003
- 255
- 0
OK, finally got around to doing the top end on the 220 (too many stories floating around concerning the stock piston grenading). Replaced with Wiseco kit (piston, bearings, rings, the whole bit) and a Cometic gasket kit. Left the head on.
Here's the question - when we were putting it back together I noticed what looked like "timing marks" on the right side KIPS valve. Little white dots on the two gears on that side. Is that what those dots were? If so, they weren't lined up with each other when we took it down nor when we put it back together. I haven't had a chance to make sure that everything (ie, KIPS) works yet, although it did start on the first kick and I let it warm up to operating temp. A couple more warm/cool cycles before I actually check full throttle operation.
I guess a service manual would be handy huh?
