Hello,
My 2004 KDX with stiffer springs front and rear and gold valves in the front wants to loose it when I hit softball sized rocks with the front (especially in corners). I am running a scott's stabilizer, and have the forks with about 3/8" gap above the tripple clamps.
Jeff Freddete set up the shims in the gold valves.
Suspension seems to work great in the tight woods, but at 40mph on the fire roads with the rocky sections it is hard to control.
Ideas? Should I put my forks back down in the clamps to stock height for more high speed stability? Less compression on the fork?
Thanks,
Phil Jensen
Thanks,
Phil Jensen
