I am replacing the carb on m '74 Suzi ts250. The old carb is trashed. I had trouble finding an OEM replacement, so instead I'm going with a different Mikuni. The stock carb was 28mm. The replacement is 32mm. The stock jets are 180 main, 25 pilot. Can anyone suggested what size jets I should use with the larger replacement carb. I went larger than stock with the replacement cuz I fugured I may as well squeeze everything I can from this old bike that now has a new top end. Thanks for your help.
