To begin with: Yes, I DID search, but only found people asking about how much oil they should use, not the result of varying it.
In the twostroke bible, A. Graham Bells "Two Stroke Performance Tuning" that is, there is a test comparing the power output from some 125cc bike using three diffrent mix ratios. As I recall the diffrence in power output was pretty big...
Has anyone else done that kind of tests? Any info is aprichiated!
