you have probably been asked 100 times ...but what is a good tyre pressure for dirt and loose dirt .....i checked my tyre pressure with a new gauge i brought and they were at 10 pounds each ...ooooppps
i usually run 12 ,my problem is ....my trails range from sand to rocky trails every place i ride so i get it all in the same day.imo less than 10 and u could pinch the tube
There's a trail riding collumn in Australasian Dirt Bike mag written by Stephen Gall (the ex-champion motocrosser). Recently he recommended that the minimum pressure that will avoid damage from rocks is 14 psi.
So, I run 14 psi generally. Under really muddy, soft conditions such as we've been having through winter, I drop the tyres down to about 12 for the sake of traction, but try to keep an eye out for sharp rocks.
By the way, you can buy special low-pressure pencil-type tyre gauges (0-20 psi) in Super Cheap Auto stores that are more accurate in this sort of range. I carry one with me while riding along with a plastic bicycle pump so that I can adjust my tyre pressures if necessary.
My riding partner who has ridden off-road for about 30 years says to run 10 rear, 12 front. That's enough to not pinch tubes or bend rims, and not too much to sacrifice traction.
