this is a follow up of sorts on an old thread where we discussed the MXbonz airbox kit installation on .02 and up CR250s, and speculated on the use of different sealants. I think it's a great kit, but can tell you that the Permatex ultra black silicone that they recommend eventually breaks down over time. Chances are, it's still doing it's job of sealing the airbox, but any excess material smeared beyond the mating surface has come broken down and flaking off. I read somewhere that there is a product called Hondabond 4 that works better, can't confirm though.
Speaking of CR250s, anyone else have trouble with the rear cylinder dowel sleeve? This is the second CR that I have disassembled with a corroded and seized in place dowel pin. It takes a lot of patience with a rubber mallet to remove the cylinder (DO NOT wedge a screwdriver in there!), and once the cylinder was removed, I was barely able to remove the dowel sleeve without making a real mess. The other (front) one looked like new.
I'm getting the "mo better" EG port job, i'm anxious to try it out this spring.
