Washer between pipe and cylinder?
yamayz125
77
Heard one said that if you put a washer between the cylinder and the pipe,
the effect will be like an aftermarket pipe.
I don`t know how thick he meant the washer should be, maybe 5mm.
Then the pipe will come more away from the cylinder.
What do you think about this? True?
adam728
1,011
Spacing the pipe away from the cylinder effectivly lengthens the head pipe. This in turn "lowers" where the powerband is. 5-10mm is usually all you would go. This would lower were the power sits anywhere from maybe 150-400 rpm. That means a little more lowend, midrange hit comes in a bit sooner, and it signs off on top earlier.
Picture a dyno run of a bike. Now slide the curve a few hundred rpm closer to the Y-axis. That's a very basic idea of what a spacer would do.
And don't throw any old washer in there. The opening in the center must match the pipe's opening. It's more of a spacer ring than a washer. Seems pretty common sence, but I remember a kid wanting to put a fender washer in for a spacer (large outer diameter, tiny little hole in the middle).
2-Strokes 4-ever
1,842
4
Missouri
I use to be a 125 woods guy. Do make sure you use the factory washers.......I usually added 3 or4. Will help the narrow banded 125's power to come on sooner. Coat o-rings on pipe with heat-proof silicone and enjoy better low end.
FRESH VIDEO
