After buying 4 of the junk oem plates I opted for the UFO. Goes on with 2 rubber straps per each side. If you go down it just moves a little instead of breaking. Looks very similar to oem plate. The actual headlight comes with 2 bulbs in it. A high and low beam I suppose. Just wire the main one up and it works great with no need for additional output that other headlight/bulbs require.
Make sure (if you get an aftermarket one) that the straps are NOT meant for USD forks. I got one'a those. Have YET to find straps to replace 'em with. Ended up using styrofoam blocks as 'spacers' to make up the difference. Kinda hokey looking.
