In the thread listed below, I talk about how I do NOT think my exhaust valve is working properly. I checked everything that I thought it would be (I was convinced after reading that if the spring was crisscrossed, that that was going to be my problem, but after going home and taking the whole dumb thing apart, that was NOT my problem!!!!!, BUT, BUT, BUT....I look next to the spring at the outer lever and I notice that the Rod isn't connected AT ALL to the outer lever, so I connect this ROD, but it feels like it isn't connected to ANYTHING inside the crankcase???? But I put it back together and test it out.......SAME PROBLEM :bang:
As I completely take the crank case apart to see what I find is connected to the other end of this ROD, and it is connected, BUT NOT CONNECTED PROPERLY, at the end where it is supposed to go in the hole of the Actuator, it isn't actually in the hole, it just slides back and forth without actually moving the ACTUATOR!!!! (or the actuator when it moves, would have NO EFFECT on the rod, which means it would move the outer lever/exhaust valve)
My conclusion is that this HAS to be my problem, unless this doesn't really "actuate" anything, but with a name like the "ACtuator" that is connected to the exhaust valve, I would imagine this has to be it. To learn more about it, I read my manual and this is what it says it does......
"This variable port action of the valve assembly is controlled by a governer (this governer assembly sits right next to the actuator, turning it) that is driven by the crank shaft. The governer is linked to the valve assembly by a control rod, and the valves open and close automatically, depending on engine speed"
In other words, since this was NOT connected at all, I guess that the engine speed was NOT changing the valve position at all, thus making it ineffective???? Does this sound like it may have been my problem??
I am just curious on some thoughts because in the process of taking the rod out, I broke the rod bushing and was not able to put it back together and test it yet (hopefully tomarrow, if anyone has one in stock??)
THOUGHTS??????
http://dirtrider.net/forums3/showthread.php?t=120399
THOUGHTS??????
