Working on rear wheel of '95 KDX.
The duct tape in place was nasty so I pulled it off and dealing with the residual tape goo is tough. Been using acetone and making progress but a lot of it has hardened. Would light wire brushing with a brush on a drill be OK?
The nipples look terrible. Caked mud and grunge UNDER the duct tape. Some of it had to be there when someone installed the tape, grrr. Soak with pentrant and try to see if they'll turn or ignore and retape? All the spoke are tight and the wheel's true (enough).
Lastly, the 1/4 inch gap between the hub and hub bearing spacer. Fill the entire cavity with grease prior to replacing the spacer? It wasn't when I pulled it out, just a light coating.
TIA.
TIA.
