bankz
58
I have 10" wheels on my xsport, front and rear. I am looking to upgrade to 12" wheel on the front. Will the 12" wheel fit into the caliper, forks etc?
thanks very much
Patman
Pantless Wonder
Provided you use the same rotor it should be fine since it's not getting bigger it's relationship to the caliper will be the same. It should just be a bolt on affair provided the the hubs is the same, otherwise you might have to locate or fabricate some spacers. No matter it WILL be worth it!
