j122687m
47
every time i ride now i gotta put oil in it keeps dripping out white out of the blaze little hose that comes off the engine
whats doing this im pretty sure there is no air leak i just want to stop it from killin my oil
thanks
usgpru27
105
Sounds like a water pump seal is leaking water into the oil. Check your water level. It should be using that also. Not sure on a Kawasaki but that hose may be from the water pump area to let you know that the seal is gone.
j122687m
47
nope found out what it was.
no water
there was water from before i did the water pump gasket
i figure i have too much oil in there because when i pull the little cap off i can see it almost to the top
and the antifreeze/water hasnt changed in the past few days of riding so i think im good
