gpoints said:Anyone have the accu-procducts compression relief mod done? We've got an '85 cr 500 that will not start cold or warm unless we tow the thing. :ahhh:
TimberPig said:Are you sure that it isn't other problems with that bike? It sounds more like something else is amiss with it. Are you sure it is that you can't crank it fast enough to start it and not other issues?
Low compression, bad reeds, fuel system issues, and electrical issues could all make it hard to start.
gpoints said:-Compression is good (too good)
-Reeds are brand new
-Fresh Fuel
-Timing is perfect
-We have a fat blue spark
We've had other "Big Bore" bikes like a YZ 400, YZ465, IT400 & IT465.
There could be "other problems" with the bike but the bottom line is the bike is just too hard to kick over. The only way I can describe it is it's easier for me to crank my RM250 by HAND than kicking the 500 with my foot.
Honda revised subsequent designs to make the 500's easier to start but those advancements don't help us much.
The jetting may be off on the slow jet but its hard to get a plug reading or do jet troubleshooting on a bike you have to drag to start; that's where the decomp-head comes in.TimberPig said:How close is the jetting set? How is the inlet needle and seat? If it isn't sealing well, it can flood the cases, making it harder to start. How fresh are the crank seals?
The mid 80's CR 500's were well known as hard kicking bikes, and the later designs with the bleed off ports to aid in kicking helped somewhat, but it should start easier than that. If it is in mechanically good shape, and properly tuned, it should kick hard, but you should still be able to start it by kickstarting. In his tips on CR 500's Eric Gorr lists some head mods to smooth the powerband and they should also help make it somewhat easier to start, if you haven't read them, you can read them here
Honda Tuning Tips
There is no way it should be that hard to start that you have to pullstart it. It should be able to be started with a good firm kick on the kickstarter. I'm not trying to say a decomp button wouldn't be worth having, just that it sounds like the bike is starting harder than it should, and the decomp valve alone may not be the answer.
Given your logic ("if the bike needed a decomp switch, it wouldve came stock with one." ), why add a free-flowing exhaust or revalve your suspension? The jetting is near perfect from the factory too, right?REARWHEELSLIDER said:Oh, be a man and put some balls into kicking the machine over. What are we, ballerinas?
If the bike needed a decomp switch, it wouldve came stock with one. If my grandpa could kick over his husquarvarna 650 two stroke in 1979, you shurley can start your bike.
No offense, just dont want to see another perfecly good two stroke cylinder head go to waste!
rws
