Motometal, I tried this trick of yours and it works awesome. I was soo tired of the spooge drooling from the front pipe junction. Now, it's all clean and I noticed it is a litle bit quieter too. :thumb:motometal said:have you tried hi-temp silicone? I don't think I have ever had one leak once I started using silicone. The only way it will leak is if you don't clean the oil off first (use solvent, etc.) or if the pipe can move enough to break down the silicone (bad mounts?)
good luck!
I have tried a few different and found RTV is good but almost too strong and gives you a hard time to remove the pipe on the next top end. Just hi-temp or even regular window silicone is strong enough to keep the joint totally leak free and wont be hard to remove. I remember my 00CR125 had a pipe gasket made out of tin. It was totally worthless and it needed silicone. The o-ring system on my 03CR250 is supposed to be better but still leaks just as bad; so silicone is still my best friend. :)teamextreme said:This high temp silicone of which you speak, are we talking about the car repair variety like RTV, just high temp, and smear it on the joint/o-ring? If not, what kind are you talking about. I just bought my son a used 2000 CR80 and it drools spooge out the pipe/head mating surface like a mofo. Hopefully this will help. I was also told that these bikes don't come with an o-ring. Anyone know if this is true, and if so can one be put in? Thanks from a first-time post'in newbie.
