keefbikes
183
I am sure I have a leak of coolent in my gear oil. It is smokey and green when it comes out. I have heard that is caused by coolant. I change every couple of rides and I dont seem to lose much coolant, infact the oil is the only sighn that I am losing any coolant. Will this do any damage if I continue to ride? As long as I stay ontop of the oil changes and wait to fix the problem until I have some time. :think:
elvismx
39
Or you could play the 98% odds and fix the leaky water pump seals.
If you leave it in there I assure that it won't explode and kill your poodle while you sleep, but coolant is bad for bearings and it sorta interferes with the OIL doing its job very well.
