pyromaniac
- Jun 25, 2000
- 377
- 0
Im trying to get my 00 rm125 to work good in my winter conditions by jetting.
-15 celsious 180 main 45 pilot. Starts first kick and works pretty good. The sparkplug is pretty white or a little light gray. The onlything is that it bogs down on the low rpm when i get into the snow. Its not normal bogging when it gets too much, it should work good.
An example, i do this long slide on high rpm, the slide gets sharper and sharper and the slower the bike goes. Finaly when the rpm gets down too much it makes this boooo sound. If i then straighten the bike up and try to gain speed by opening the throttle is just boooo. I close the thottle and open it just a little and when it finaly gets a little rpm then it jumps away to the high rpms pretty quick. I tried to use the choke and it doesnt change the bike much other than the idle rpm is higher.
What do you think this is, too lean pilot? too lean main jet?
