Home
Basic Dirt Bike How-To's - Video
Living The Moto Life - Video
Bike Tests | Shoot-Outs - Video
Forums
What's new
Latest activity
Log-In
Join
What's new
Menu
Log-In
Join
Navigation
Install the app
Install
More options
Close Menu
Forums
MX, SX & Off-Road Discussions
General Moto | Off-Topic Posts
Winter Make Over
Reply to thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser
Message
[QUOTE="Mac, post: 1045034, member: 18503"] I had Factory connection rebuild/revalve my forks and shock, they also installed stiffer springs. I sent my hubs to FRP to have a set of Excel rims installed. I will also be replacing the wheel bearings and installing a new set of S12's I tore the top end apart to replace the piston/rings, I also spent two days cleaning the power valves.... :blah: While I had the head off I adjusted the height of the cylinder studs, they were too low. I also installed an extra base gasket to see if I can run pump fuel again. Carb was completely tore down and cleaned, float height set. New brake pads installed, welded the kickstand bracket (it was too sloppy) and grinded the endstop so it retracted higher. Drank lots of beer. [/QUOTE]
Verification
Which ocean is California closest to?
Post reply
Forums
Winter Make Over
Accept
Learn more…
Top
Bottom
