I need help or any suggestions!
At Summer Bummer Sat event , my son hit a tree on the left side of his 2004 Yamaha WR 450. The radiator was leaking, but not that bad, I thought. We tried to finish the loop to get water, but we came up short about a 1/2 mile from the end and the bike quit running. It kicked over and seem to have good compression, but hard to tell with the auto decomp.
When we got home, the bike started right up, so I filled it with water to see if any bubbles were coming out the top of the radiator, to check for a leaking head gasket. No bubbles, looked fine.
Next day, come home from work, go to start bike and no start, not even a blubber.
Replaced spark plug, has spark but no start
Checked for fuel in the bowl, good. Seems to be getting fuel. Accelerator pump even squirts.
Air cleaner in tact, no blockage.
Disconnect kill switch on left side handle bar, still no start.
Pulled valve cover and checked valve clearance, intake and exhaust are absolute perfect to specs, all five valves.
Plugged off all coolant lines and pressurized the cooling system for a leak test. went up to 40 psi and it held it, no leaks.
A couple days later, bike starts but will not idle or run smooth. I have to have the throttle cracked abount an 1/8 to get to start.
Maybe the TPS, so I disconnect it, no difference.
It sounds like it may be no fuel on the idle circuit, take off bowl, pull all of the jets, main, idle and starter jet and they look clean, but cleaned them anyway, and still runs rough and no idle.
In the mean time I notice the hot start cable plastic nut is busted off from the top of the carb(result is pulling the plunger up). The choke pull is also bent(left side crash into tree??). I bought a new choke pull assenbly, and pushed the hot start plunger all the way down in the hole where it is suppose to be, and no difference, still runs rough and no idle and very hard to start.(I'm still waiting for the plastic nut)
When it does start the bike will rev like crazy if I want it too and sounds good at a higher rpm.
Do a compresion test and realize the auto decomp gives me a very low reading. I take the spring off the exh. cam for the auto decomp to be disabled, get a higher reading but still seems too low. Now I think it is a head gasket ,sticky valve or stuck rings from the overheat. Pull the top end off and every thing looks brand new. I can't belive running it that low on water didn't even leave a scratch in the piston skirt.
The head gasket shows no sign of leakage, and the valves look to be all closed(I need to check to see if the valves seal with liquid)
I need to pull the flywheel and look for a sheared woodruff key(ignition timing). But I don't have a puller right now.
I'm going to completely disassemble the card and look for any dirt in the fuel circuits.
I also need to look for any possible pinched wires.
After this I am out of ideas. If anyone has any suggestions or expierience with something like this, please reply. I always thought I was a good troubleshooter, but this has me stumped right now. I'm also prepared for the simple/stupid solution that I have not thought of, and I'll have to post it and embarass myself. I just want my kids bike running so we can go to Stumpjumper. :bang:
