its an xr80 but i figure it wont get any replies in the mini fourm so ill put it here. it will idle but only at a high rpm, if i turn it down it will die. the throttle responce is ok at best and is best w/ the air screw all the way in. it has the stock jetting (pilot is 35). i adjusted the valves and it got better but its not perfect yet. it wont restart w/o giving it some gas as u kick or it will start and go for a few seconds at a low rpm then die. i suspect an air leak but where could it be? could the air boot beeing loose where it connects to the air box cause an air leak? it is loose(will go up and down) when not connected to the carb. the gasket inbetween the bowl and carb body is also missing and it leaks some gas. what could i make that gasket out of?
