The bike stalls when twisting the throttle fast from idle to 3/4 or full throttle. Gear in neutral or in any gear.
No matter if the bike is warm or cold.
And I haven´t touch the engine before this started, it just happened.
After it has stall in this way I can´t start it up in first kick, that it usually takes. In second kick it will fire up.
The old sparkplug was black and sooty. I have inspected it before the problem started and then it was gold/brown as it should be.
What I have done:
Put in a new sparkplug.
Cleaned the carb. with air pressure.
Raised the needle jet one step, no difference so I put it back as it was before.
Tested without air filter in it (just for some seconds), to see if it was clogged.
Raised the idle, didn´t helped.
Played with air screw, didn´t helped.
So still the problem is there.
Jetting: 175 main, 65 pilot, needle in 3th(from up). Air screw 1 3/4 out.
Please help me out!
What I have done:
Please help me out!
