XR650R how much rear shock sag?
Richard-XR
9
Hi,
On my used XR650R I just bought, the difference in rear sag between when the bike is just sitting without me on it and when I pull it up is about 3-4 inches.
Should it have this much sag without a rider on it?
I weigh 225, so I'm wondering if this is way too soft.
Also do you need a spanner tool to tighten the spring?
Thanks much for the help!
Richard
Marklx
278
Sounds way too soft. Sag off the bike should generally be around an inch or so, and about 1/3 of the travel when you're on the bike. Check out the mx-tech site for good guidance on setting up sag.
As for needing a spanner, haven't bought one yet. Just using a big flat blade screwdriver and hammer with the bike on a stand. Once the lockring is loose, I can turn the spring by hand easily.
Mark
Buckholz
396
Richard, you should have about 3/4" free sag (bike weight only) and 4" of sag with you on it.
You can make the bike work alot better, by setting it to the 3/4" free sag by adjusting the spring preload, but..... to get it exactly right, you will need an Eibach 10.5 kg/mm spring from White Bros.
I weight same as you, and needed stiffer front and rear springs for my BPR. Eibach is the best supplier of springs for the Big Red Pig.
I use a punch to adjust the collars, yes it dings them up, no it is not a problem....
