i have a 93 yz 125 that runs decent but seems to load up on the low end and be down on power in the low end right up into most of the mid range. i cant seem to find much information about the jetting, needle clip position and air screw position as far as how it came stock. i know it came with a 330 main jet, 20 pilot and a 56 needle but no luck on clip position.as of now i have the clip on the second notch down and the air screw i have tried in many spots. At 1.5 turns on the screw it still seems to want to load up but when i try any more than 2 turns it idles high but runs slightly better. but regardless of air screw position when i let the bike idle down it will idle good for a little bit then start loading up again and i have to play with the throttle to keep it from stalling.
i got the bike giving to me as a gift and have been trying to fix it up. when i took the carb off for the first time it didnt even have the needle retainer so the needle just kind floated around it there. so i went and bought that little 25 dollar plastic piece thinking it would fix my problem but it didnt. it made it a little bit better but not fixed it.
the first time i took the head pipe off (stock) it had so much carbon build up right off the from the edge of the exhaust port far down into the pipe, i couldnt believe it. i cleaned it all up the best i could (from what i can see) but with still no luck.
i have taken the cylinder off and it has a wiseco piston. with the cylinder off i cleaned it up and put it back together. i can open the power valve open easy so i dont think its sticking/stuck. oh and it blew 135psi of on my compression tester with about 15 kicks.
really sorry for the long thread guys but i just really want to figure this problem out. i know these bikes dont have the best low end any way but it shouldnt be like it is i know that. with that much carbon build up in the pipe do you think it could have a bad crank seal causing it to burn tranny fluid and cause my issue if thats even possible? any help or thoughts would be great guys. thanks for your time to read my long thread.
