I decided to take my 2001 YZ250 out on the trails to get the jetting straightened out. I'm running pump gas mixed with Yamalube at 40:1, with 2.9 hours on a new top and bottom end. It has never run right, at least in my mind, but I figured this had to do with the FMF Q Stealth spark arrestor I added. Before heading out, I marked the Closed, 1/4, 1/2, 3/4, and Full throttle positions on my grip. It was sounding pretty blubbery, so I went from the stock 50 pilot and 178 main to a 48 and 175.
Just barely cracking the throttle, this thing comes alive, but I get no change after 1/4 throttle, meaning no increase in pull, but no bog either. It's as if that last 3/4 makes no difference. Just before loading the bike back on the trailer, I checked the RPMs using the hour meter, and it was showing over 8000 (maybe closer to 9000) under no load. Assuming my hour meter didn't lie, is this normal?
