If you need working lights to get through tech at an enduro, and dont want the to buy the $400 lighting coil, I found that the bike has a charging coil already for the fuel selenoid, I tapped into the red and white wire out of the voltage regulator, added a kdx switch to turn the lights on and off, a head light and tail lite, I used very low wattage bulbs, It works fine for getting through the tech line, then just turn the lights off when its time to race! BTW this is a very good enduro bike, the suspention works good after you take some rebound dampening out!!
