Rockey5000
Mod Ban
May 6, 2002
293
I'm confused, I did some research and have found that 2-Strokes make their best power and longevity at 18:1. Why don't more people use this ratio? All the money that people spend on powerups for their bike and they run it at 50:1? It just doesn't make sense to me. Can someone tell me the disadvantages of this ratio? I want to switch and need to figure out how much richer to jet the bike to make it run right. What do you guys think?
125 rider
408
Because most poeple probably dont know how to properly jet a bike so switching to a radically richer oil mixture (or leaner air/fuel mixture) will leave them with a poorly running bike. I run 32:1 in my bike because 1. thats what its jetted for, 2. it's an adequate amount of protection for my riding style and conditions, and 3. because 2 stroke oil is not cheap and with the amount of riding I do i'd be going through buckets of oil a week at 18:1.
rc331
101
A two stroke will make more power with a higher ratio of oil to fuel up until the point of fouling the plug. I think the disadvantages would be like 125 rider mentioned cost of pre-mix oil would be out of this world, jetting would be a nightmare, spooge would be a problem, carbon deposits on the head would be a problem, powervalves are already icky enough to clean, there would probably be no mosquitos (a good thing ) as they would all be dead due to smoke but the greenies would have a real reason to complain. Throttle response may suffer?. Silencer packing life may be shortened. ;)
Jaybird
Apprentice Goon
6,452
Charlestown, IN
You can jet your bike for what ever ratio you choose to run. However other factors enter in like, humidity, elevation, and riding style.
I'm a bit confused, rc331...are you saying these events will happen when going to the 18:1 ratio or the 50:1?
rc331
101
I was thinking this stuff could happen at 18:1 maybe I'm way off base?
also doesn't the addition of oil to gasoline lower the octane rating of the gas? I suppose you could re-jet and avoid the problems I mentioned in my earlier post but would you be able to run 18:1 on pump gas without detonation?
Jaybird
Apprentice Goon
6,452
Charlestown, IN
You are indeed off base, rc331. That's why I asked.
If you are jetted up for 50:1 and you got to 18:1, I realise that conventional wisdom would say you would have fouled plugs, spooge, and the like, but it is actually quite the opposite.
Too much to go into, do a search and be enlightened. :)
rc331
101
Jaybird
o.k I did a search but enlightened I'm not....more confused...maybe! :confused:
Originally posted by Rich Rohrich
Using a high volume of oil and pump gas in a high output two-stroke engine is a REALLY BAD idea.
Jaybird
Apprentice Goon
6,452
Charlestown, IN
Well, for one thing, if you are after optimum performance, pump gas will not help you to succeed. It is very inconsistent, to say the least.
When you are running a high volume of oil and jetted up correctly, you should be close to the edge of being lean. Detonation is bad and pump gas can contribute to detonation.
Keep in mind that many times Rich will be describing high performance tuning with the maximum output as his goal.
Take look at this thread:
http://www.dirtrider.net/forums3/showthread.php?s=&threadid=49832
David Trustrum
1,396
Ooh ooh! Can we get onto what brand oil is best to use next? My personal favourite is:
Honest Dave’s slippery eel oil. Made from recycled sump oil it comes to you pre-tested, no other oil can claim that.
It is best run at 50 parts oil to one part petrol so you buy more.
Send your cheque to. . .
Rockey5000
Mod Ban
May 6, 2002
293
If you jet correctly at 18:1 the plug will not foul any more frequently than ay 50:1. Premix cost is a disadvantage, but an engine costs more. Jetting wouldn't be any harder than at 50:1 or 32:1 etc. If the bike is jetted correctly spooge would not be a problem neither would carbon deposits on the head or excessive smoke. Throttle response would be increased on a correctly jetted bike as the extra oil increases compression and extra compression increases throttle response. Silencer packing life wouldn't be shortened with out spooge in it.
Jaybird
Apprentice Goon
6,452
Charlestown, IN
rc331...very cool!
Don't feel lonely though, I talk to guys who think they are ace tuners (racer dads, bike shop mechanics, A riders, etc...) who still think that if your bike is spooging, the simple solution is to lessen the amount of oil in the ratio.
They are clueless, but if you try to have a decent discussion with them, they will let you know right away that THEY are the pro tuners and know what they are doing. Mere mortals can't compete with genius' such as those. :)
Rockey5000
Mod Ban
May 6, 2002
293
rc331 I was in no way flaming you! I understand where you were coming from and was trying to address what many people believe about using more oil. Im sorry if it came off as a flame, I didn't mean it that way.
125 rider
408
So what was the real question here? I think you've answered them all yourself :confused:
Rockey5000
Mod Ban
May 6, 2002
293
The question is why do people who spend $1000's in performance mods and top ends overlook this simple and effective way to increase performance and longevity.
2001yz250
501
So why not just run a 1:1 ratio or just put all oil in it and no gas? This is not a flame by no means, I'm just intellectually challenged! :ugg: There has to be a limit somewhere, is it at 18:1?
marcusgunby
6,450
As others have said eventually you will dilute the gas and cause detonation.For max power on good fuel 18:1 is a good ratio.I run at 32:1 on mine just because oil is expensive.
Rockey5000
Mod Ban
May 6, 2002
293
If you want the best mixture, run race gas with 18:1. I run Cam-12 110 Octane race gas with an 18:1 mixture of MX2T. The added performance is very noticible.
Rockey5000
Mod Ban
May 6, 2002
293
Yes, one main jet size, one pilot jet size, and one or two clip sizes up will compensate for the change. Are you running race gas or pump?
2001yz250
501
Normally I run pump but I bought a couple of gal of race gas and I can't tell any difference, maybe even less performance. I have a gallon left unmixed and was thinking of trying a different ratio.
