1996 rm250 leaking oil on shifter / sprocket side?
mideastrider
827
most likely the oil seal behind the sprocket or oil seal on the shifter shaft. No gasket. Take some brake cleaner clean it up good and you should be able to tell which seal is leaking. If its the counter shaft seal get the metal collar the o-ring and the seal.
Chizzholm
20
Great man thanks.
