2000 yz 125 in need of a new top end and making weird noises
lazywaffleman
22
Well, i have the manual for it. I have a video that I would post but it wont allow outside links.
Also I trying to find out if it is in fact a 2000
Where is the vin located?
"10th digit applies to ALL Japanese dirtbikes", after a little searching? So its a 1980? Big difference there! I knew the 10th digit as a Honda thing? Does the engine and frame vin match? Vintage Bob
MXSparx
Mr. Meltsomeglass
Jul 25, 1999
3,724
71
NoVa
I think the VIN should be 17 digits and on the frame at the steering head or steering tube below the bars on right side
lazywaffleman
22
Weird, I got the vin right off of the steering head. Well I would add a picture or video but i cant. When can get the ability to do that?
Heres the corrected vin
JYACE05C5YA011339
MXSparx
Mr. Meltsomeglass
Jul 25, 1999
3,724
71
NoVa
2000
10th digit is y=2000
For example: 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994(R), 1995(S), 1996(T),
1997(V), 1998(W), 1999(X), 2000(Y)
2001(1), 2002(2), 2003(3), etc.
lazywaffleman
22
ok, now thats solved
If you search "Yamaha yz 125 Bad top end" on youtube it is the first result. Tell me what you think the duck like noises are from
ellandoh
dismount art student
2,958
blow by;
sounds about right for a 0psi compression top end
ellandoh
2,958
part of the regular maintenance on a 2stroke mx bike is a complete top end rebuild. which can be done thoroughly in about 2 hours once you get it down .
the answer is, do the top end before you attempt to start it again. maintenance has been slacked.
It would be ideal to take the engine all the way down, replace all the seals and bearings. Kits can be had for under a couple hundred. By then, replacing the crank and top end for sure. I am guessing 5~650 dollars you will have a fresh engine and KNOW everything is in spec. And start counting hours of run time. Vintage Bob
Yes, you would need to go through a break in on new bearings. It's even more important that the bearings are broken in properly than the top end.
lazywaffleman
22
The shop called today and they said the engine was fubar.They ordered the parts. They also said they the cylinder was pretty messed up and they are over boring it or something. Basicly im getting a new engine when everything is done.......... In 3 weeks
:bang:
