I have spent countless hours trying to set-up my 02 CR250 and have finally come up with a jeeting setting that is acceptable but not perfect.
The power is incredible and smooth but blipping the throttle right of the very bottom (1/16th-1/8) is not as crisp as any of the 2002 model 2 strokes I have ridden. The rest of throttle range is perfect.
After a lot of trial and error and countless hours reading the forums on this excellent site I have come up with the following.
I ride motocross at sea level at approx 70 deg F. with stock reeds and FMF shorty silencer.
400 main
6BEY30-75 needle 2nd clip
30 pilot
Air screw 2 turns out
S8 Yamaha needle nozzle
Slide filed 0.75mm to make it a 5.0
I have tried the 76 needle and it is a little to lean with the S8 needle nozzle mod.
I dont no if the Mikuni carb is the problem and a Keihin would be better suited to this engine.
Also what silencer to do you guys prefer. The FMF shorty or the Pro Circuit R304 shorty? I run the FMF shorty with the stock pipe and I am not that happy with the silencer perfomance. I believe Honda makes great stock pipes and thats why I have stuck with the OEM version.
Which rear sprocket 49T or 50T? I am thinking of running a 50T!
400 main
30 pilot
