marcusgunby
- Jan 9, 2000
- 6,450
- 2
Right then the externals first;
It is a largeheavy shock-it runs a 50mm body-only showa as far as i know use a 50mm.It is a steel machined construction rather than a forged alloy.
It has a 18mm shaft-so it displaces alot of oil through the comp adjuster.
It has a comp adjuster that goes backwards to most normal shocks-the 02 has a normal adjuster.
It uses a progressive spring.
The springs are of 2 types 250mm long ie PDS1-250
or a 265mm long spring ie PDS 6-265.
The 2 springs have a different point where they progress.
The rates on both set of springs are similar.
I will do the internals and history of the pds later.
If anyone has any specific questions on the shock please ask so i can direct the thread.
