yankeefan4life72
- Sep 15, 2004
- 195
- 0
Just bought a 2005 yz 85 and went to change the oil....but cant find the drain plug. it is not on the bottom of the motor.I see a bolt with a copper washer on the side cover where the brake lever is.i drained it through there.how do you check the level??no sight window and i dont see anothe bolt to check the level. i put 500 ml back in.on my cr 250 the drain is on the bottom and the level check is a bolt on the side cover.any one???? :think:
