whenfoxforks-ruled said:Spam?
NAH, just dementia. ;)
Patman said:I think you need to use Amsoil.
juniordragster123 said:The lobe doesnt look all that bad. I'd remove the cam and get it polished and check into why it happened.
Rich Rohrich said:Assuming the pilot jet isn't partially blocked, and the exhaust isn't sucking cool air in at the head sealing surface, it's worth starting with richening the low speed fuel screw. Once it gets warmer you can probably lean it back out some.
magneto said:What all did you finally end up replacing in the rebuild?
Rich Rohrich said:Indy - If the cam gear slipped you should look closely at the cam chain tensioner as a reason why. If the cam chain "whips" the sudden load/unload/load sequence could be the reason for the gear movement.
IndyMX said:His problem was that the gear on the intake cam shaft had slipped. He checked ours, and sure enough, it had moved.
He reset it, and tig welded it in place, runs like a cut cat.
2strokerfun said:Indy: Just curious here. Are those gears pressed on the camshafts?? Looked up parts fiche and appears gear/shaft appear to be sold as one unit.
question 2: How the heck would an average person would even be able to recognize a slipped gear on the shaft? Is there a mark?
whenfoxforks-ruled said:Even on the Honda's, using or buying something to check with a degree wheel is priceless! Just like pulling the trigger on your judgment calls?
