At this point I sent my carb to the dealer. I requested for them to FIX it or replace it. After all, a $7500.00 NEW bike should work! :think: By the way, I just found my side stand bolt on the floor. It appears that the side stand bolt broke! :( (the section that goes through the rubber chain guide - any suggestions for the '03 bike stand mount?).
In my carb fix research, I inspected all the jets and found them to be the proper stock numbers (200MAJ, 100PAJ, OBDVT#3, 178MJ, 42PJ, 85 other jet??). In the many iterations, I did try an adjustable PAJ and tried 7/8 through 1 1/4 turns. This did not make much of a difference, and nothing was noticeable with respect to the number of turns I had on the Fuel Screw (FS). Could there be a leak on the choke? maybe, I did not check or know how to. I did checked and eventually replaced all the manifold clamps (they got damaged from the many on/off installations of the carb). I also did try the OCEMN and OBDVP needles. Both worked much better than the stock needle, but did not effect the FS turns. I also adjusted the valves (they were way too tight).
Could the problem be on the ignition (I think very unlikely) or the rev. limiter on the carb? I am baffled! JC
