:bang:
I will be ecstatic if any can help me with this one. Here goes:
1990 CR250R
Keihin PJ38 (already rebuilt)
main: 170
slow: 55
air screw 1-1/2 turns
needle: 1370
float: 16mm
it is getting plenty of fuel
engine compression is good.
spark plug: NGK BR8EIX
stock reeds look OK
PVL ignition system has been bench tested by Penton imports and show OK. timing is set to 2mm BTDC
FMF Gold pipe with repacked silencer
fuel: 32:1 93 octane with synthetic
The problem:
When I kick it over with the plug out, it only sparks 60% of the strokes (Penton says this is normal for slow revolutions on their PVL system).
I cannot get it to start at all. Every time I kick it over, it sounds like the first kick wants to start, then any after that, nothing. I pull the plug after the first kick and the plug is soaked. There is no fuel down in the crankcase, I have checked that. Timing has been changed from 15mm - 0mm BTDC, no difference.
HELP!!!!!
1990 CR250R
main: 170
slow: 55
needle: 1370
float: 16mm
stock reeds look OK
The problem:
HELP!!!!!
