slapshot1540
- Jul 27, 2008
- 53
- 0
got a 96 cr250. took the carb off to drain old gas out. now when i open the petcock it pours gas out of the bleeder line. What happened?
I assure you its really not that hard. Just a couple bolts and its off. On my 00' CR, i remove the number plates, then loosen the airfilter box to carb clamp, and remove the 2 bottom bolts on the subframe (I only loosen the top), and just swing the subframe upsidedown. Then pull the carb off. The more I take off, the easier I find it to be.slapshot1540 said:thats what i figured was wrong it i just wanted to make sure it wasnt something else. i dont know how it woulda happened but o well. anyone know how i can avoid having to take the whole subframe off this freakin bike just to get the carb off and on?
