meyaya said:Will removing the airbox lid produce any gains in performance?
BTW: putting panty hose or window screen or wire mesh over the top might keep out the big stuff, but the air filter will do that, so what's the point?
I could tell you, but then I'd have to kill you. ;)james.keaton said:why do 220 riders switch to the 200 carbs.
Why did kawi even produce a KDX with inverted forks for one year and then change back the following year?
And last but not least..."How exactly does the posi-trac rear end on a Plymouth work?
meyaya said:Will removing the airbox lid produce any gains in performance? ...wondering if there is any noticeable gain when only the lid is removed. Thanks, Jeff
No, but putting the lid back on would. :cool:meyaya said:would a FMF pipe, silencer and airlid removal cure my throttle response problem?
