adub24
13
Does anyone have any recommendations or good experiences with a particular kind of race gas ? I have the athena 144 in a 2005 yz . In the athena instructions it recommends 96 octane or higher and the compression is 14.8:1 . I think the c12 is a safe bet but wanted to see if any of you had others you like better .
ericz103
120
I don't think compression is 14.8 to 1.
I have the same kit and run 93 pump gas, but not going to recomend to others... its at your own risk.
I had trouble with detonation once but that was due to loss of coolant/overheating I believe.
adub24
13
Found some 100 octane pump gas I am going to try . Is there any advantage in performance with the c12 over this ? I don't mind spending the money if it is noticeable .
