Battery Powered headlights and a KX100?!?
Discussion in 'Bike Mods, Performance, Maintenance & Repair' started by Blinkme7182, Aug 4, 2001.
  1. Blinkme7182
    Blinkme7182 Rookie DRN Member
    Sep 30, 2000
    46
    I've decided it would be too involved to put a regular, engine powered headlight on my KX. My question, does anyone make battery powered headlights for dirtbikes? Or would have to use one that was made for a Bicycle? Also, would these battery powered headlights pass as a sufficient light source if/when I go to register my KX for riding in state parkks? Thanks a lot
  2. DMATT125
    DMATT125 Rookie DRN Member
    Feb 25, 2001
    36
    im not sure if anyone makes a battery powered light specificly for dirt bikes.i just strap a big flash light (the 9v type) to my front fender with bungee cords works great.
  3. rames90
    rames90 Rookie DRN Member
    Sep 7, 2000
    94
    I just use a bicycle headlite and tail light they each take a couple of batteries and if I break them they are cheap to replace. They are sufficient to satisfy the Park Rangers here in Alberta. But I should also point out theat if I got lost and had to ride home in the dark the headlight would not be safe to ride home with through the woods. I tried it on the weekend, it barley lights up the ground five feet in front of me, with new batteries even!
  4. Heywood
    Heywood Rookie DRN Member
    Feb 18, 2000
    34
  5. cujet
    cujet Member DRN Member
    Aug 13, 2000
    827
    16
    There are also HID battery powered headlights for bicycles. They are very bright and have low power consumption. This would be a very good option for a motorcycle. They are expensive.
    Chris
  6. EricGorr
    EricGorr Super Power AssClown
    Aug 24, 2000
    790
    Acerbis sells a headlight/number plate combo kit that straps on fast. You can power the lights with a 12V Nicad battery.
    The set-ups for mountain bikes, particularly the Halogen products work excellent but are expensive. So depending on if you want minimum lighting to comply with daytime enduros or actually want to ride in pitch dark and actually see will determine what product you need to do the job.
    Tell us what you need the lighting capability to do?
  7. DMATT125
    Feb 25, 2001
    36
    ERIC GORR
    right now im using the old flashlight trick as stated above. but i would like to upgrade to a better battery powered set up.i would be riding at nite in the woods,and would need maximum lighting. what products do u have in mind.
    thanx
  8. EricGorr
    Aug 24, 2000
    790
    Look to the mountain bike marketplace. There are dual halogen kits with rechargable batteries for around $250 that can be mounted in different configurations including on your helmet.
    Good luck
  9. DMATT125
    Feb 25, 2001
    36
    thanx eric.
  10. Blinkme7182
    Sep 30, 2000
    46
    I wouldn't be riding in pitch black, mainly I need it in order to register my bike, and sometimes I go riding and don't get back until around dusk, so in low light situation--Eric Gorr---can you send me a link for Acerbis' headlight? How much do they go for? Where can I get them? Thanx
Similar Threads: Battery Powered
Forum Title Date
Bike Mods, Performance, Maintenance & Repair Can you use a battery instead of a stator Oct 2, 2009
Bike Mods, Performance, Maintenance & Repair battery keeps going dead on 2001 yamaha ttr 225 Aug 25, 2009
Bike Mods, Performance, Maintenance & Repair capacitor vs. battery Sep 22, 2008
Bike Mods, Performance, Maintenance & Repair 6 volt battery 12 volt horn, help! Apr 16, 2008
Bike Mods, Performance, Maintenance & Repair Remove Seat / Battery TTR 90 Jul 24, 2007
Share This Page
