Boyesen Rad Valves vs V-Force Delta 2 Reed Valves
mlhend1
186
I'm in the market for new valves. I'm looking for mostly a boost in the low end performance of my kdx 200, mid and high end would be a plus. Which valve is recommended Boyesen Rad Valves or V-Force Delta 2 Reed Valves? Where is th cheapest pace to buy?
GREENHORNET
119
for low end response and better response over the whole power band a get boysen rad valve Jeff fredette recomends this and if you still want more low end get a torque ring from Fredette racing Rad valve is $120 at rockymountainMC.com i got it for 126 dollars shipped
canyncarvr
4,005
Buy both of them and decide for yourself.
You'll often find a rider looking for a good deal on a radvalve so you'll be able to recoup at least some of your cash.
Robcolo
342
GO to Canadian Dave's "hop up Guide" and read what the final consensus is on the Rad Valve[$160 for no detectable difference] The Boyesen 2-stage reeds will give you increases on both top & bottom ends
