Here is a little paradox that I found intriguing. The solution took me a little bit of thought. The question is this: We all know that engines in general require an approximately 15:1 ratio of air to fuel which is mixed by the carburator. This means 15 parts of air are burned up for every 1 part of gasoline. So if you burn 2 gallons of gas, you should only be sucking 30 gallons of air through your air-filter.
The question is, why do filters get dirty so fast when they are only passing a small amount of air through them?
