- Jul 16, 2004
- 1,207
- 0
I have 96 RM250 with boyesen reeds and cage and a fmf fatty pipe. I haven't been able to ride much lately due to school but when i took it out last it ran bad. It was really hard to kick over but eventually it would fire up. If i would try to go from idle to wide open the bike bogs down then catches back up with the gas. It was running a 45 pilot and a 168 main with the clip in the second slot on the needle. I changed the pilot to a 55 and the main to a 175 and the clip back to the 3rd slot. The bike fires up a lot easier now but still having the same throttle response when i try to get on it. The plug doesn't look to bad, actually looks the right color now. I cleaned the air filter but the problem still persisted so I have a new one on the way just in case. Any other tips on how to straighten this out would be sweet. The temp in the summer is 80-90 degrees with pretty high humidity and i ride at sea level.
Thank You
Thank You
