- Jan 8, 2000
- 3,331
- 1
- Thread starter
- #26
The 1174 has a larger diameter than the 1172 (2.745 vs. 2.725) so it is a leaner needle on the diameter only. They share the same taper and I assume L1 (since you didn’t provide it). I would suggest that you use needles that reference the Keihin part numbers. These numbers are much easier to understand. For instance, the 1173N needle crosses over to a BGN.
What part of the needle do you want leaner? There are three sections to a needle, all affecting the characteristics of the jetting. The first letter is the taper. A “C” needle is leaner than an “A” from ½ to ¾ throttle. The second letter is the L1 (length) that affects when the taper of the needle comes into play. This can be adjusted with the clip and is effective from 1/8th to ¾ throttle. The last letter is the diameter. The higher the alphabet number, the leaner the needle. The section has the greatest effect from 1/8 to ¼ throttle.
Of course, a change in the needle will likely require a change in the jets. What modifications and jets are you running on your 220?
