U P rider
I just replaced the clutch cable on my 2004 Yamaha wr450f.Had a frayed cable. Not sure if the size is incorrect or if its me. It was tight getting it on for starters. Now that its on when I start the bike the rear tire is engaged even in neutral. The tire spins at a slow rate but spins. I took it for a short ride around the block and the clutch does work but you can tell the engine is still engaged even when clutch lever is pulled in? Any suggestions?
