- Jul 16, 2004
- 1,207
- 0
Today i decided to take my RM out and it was running excellent. I only burned around the open field near my house so nothing crazy. When i was about to head back to my place the clutch started acting real wierd. I got on it and hit the powerband and when i shifted into 3rd it kinda hesitated then finally caught, same with 4th gear. It was like it slipped real quick then caught back up. I got home and pulled everything apart. For some reason the adjustment piece on the perch was all the way in which gave my to much play. I wasnt sure if the cable was just shot or not so i pulled it out and it looked fine. The clutch itself is perfectly fine also. I put the clutch cable back in and adjusted it and it seems alright but i didnt take it back out yet tho, prob tomorrow. Is it possible for my clutch adjuster to adjust itslef from vibration that quick to cause it to have to much play? Everything else looks fine but i dont want to run into this problem again. Just seemed odd that it was perfectly fine then all of a sudden it was way out of adjustment. Anything else I should look into, maybe get a new cable just to be sure?
