Cr 85 seized ?
The kick start is completely stiff, i tryed putting it in gear and moving it to see if i could push it through the gears and i couldnt.
What would be the cause of this problem, why would it just seize?
If it is seized how much would it cost to repair? Or could it be another problem like the pistons or something ?
how much money am i looking to fix it ?
Super Power AssClown
#2
I would say somewhere around a buck two ninety eight. :whoa: Might be less if you do the work yourself.
Nobody knows until you pull the head and cylinder and find out what seized. That would be the first step. :cool:
you might be lucky and it only be the piston . or unlucky and it be the bottem end bearing gone which is costly. just take the head off and youll fine the problem
- a d v e r t i s e m e n t -
