Hey guys, as I was taking off the tires/rims on my 96 CR250, i took a good look at my sprocks and chain. The chain was shot to hell, as it makes a squeaking noise when you move it around, the tops/bottoms are severly worn, and you can bend it side to side. I'm thinking about going with an "X" ring chain, after seeing all the "no maintenence no stretching" posts about em in this forum. The sprockets were horrible also. The teeth were way too wide, and some are larger than others. I don't know anything about sprockets, I was looking at this for the front sprocket ( front )
And mabye this for the back ( rear ) ? Does the teeth-count really affect performance Power/Speed that much? Thanks for your time and info! -Darkfox
