- Feb 6, 2006
- 255
- 0
Well, Honda's not making them so I did. Thought some of you might be interested in a minimalist street conversion. I just had it inspected by the sheriff and signed off for all of the on road equipment required by the state of Michigan ( http://www.michigan.gov/documents/TR-54_38480_7.pdf ).
I bought a used CR450x headlight off the auction site and bought the CRFx headlight mount kit from applied racing ( http://appliedrace.com/store/catalog/product_info.php?cPath=3&products_id=1380 ). I had to modify those mounts slightly because the holes didn't line up with my cr250 triple clamps. I filled in the bottom hole with my tig welder and redrilled it. I made a custom bottom bracket that attached to the two holes in the bottom of the CRF headlight and has a single hole at the back that slips over the single post on the cr250 bottom triple (the CRF has two on there). That took care of the headlight.
For the taillight I went with Baja designs led taillight kit - https://www.bajadesigns.com/NET/item_detail.aspx?ItemCode=600709 . For the brake light switch I used a replacement banjo bolt from ( http://www.kandstech.com/index.php?page=brakeswitches# ) that has a built in switch on the rear brake.
