Mike_socal
- Oct 1, 2003
- 189
- 0
I installed new cylinder studs and locating dowels on my 01 CR250. I greased the studs and torqued them to spec which by the way doesn't sounds like a lot, 106 in lbs. Should I have put some sort of lock tight on them? I don't want to run into the situation of trying to remove the cylinder nuts and have the studs spin out. The original studs and locating dowels were pretty corroded.
