I took my 81 KDX around the block to get some fresh fuel into the carb , then turned off the gas as I often do to gently run it until it dies. It started to sputter, pulled into the garage then WAAAAA! went lean and stayed at max revs for about 30 sec, kill button did nothing. It eventually died and didn't sound like it seized, kick starter moves the piston fine. Should I worry or check anything? I was messing with the idle screw and had it turned in pretty far, trying to tune out a bog but having the screw so far in is probably what caused the issue. Kind of scary, I couldn't kill it and just held both brakes full tight until it died, I was picturing it clicking into gear and launching into the garage wall.... :yikes:
